Using Appliance Ports for NAS
kg6itcraig
Hey all connecting a NAS to UCS. Would like to plug in directly to FI’s using the Appliance Port option.
Are the steps basically
  • Turn on Ports use as Appliance Ports
  • Make PIN Group through Appliance Ports (this will only be one port per FI, I am guess Port-Channels can be used if NAS supports that?)
  • Make VLAN internal to UCS
  • Make vNIC Template and use newly created VLAN and PIN Group
Boom!
Right?
Thanks!
Craig
My UCS Blog http://realworlducs.com
5 Replies 5
Robert Burns
Have a watch of Brad's great video explaining it all.
http://www.youtube.com/watch?v=TNNiYTcvw8I
Robert
v-crsimp
I have made port 20 on each 6120 an Appliance Ports.
Each port is assigned to a VLAN made under the Appliances tab.
Cannot seem to make a PIN group using these Appliance ports. They are not a option.
Is there something I am missing?
Thanks!
Craig
Can you please specify what kind of devices are you going to connect to these appliance ports ? I mean are they going to be FCoE target or iSCSI target?
NFS
Craig
Thanks. I will assume you are connecting iSCSI storage target ports at the appliance port and iSCSI target will have NFS share.
