Virtual-service-blade reduncancy not working
I have a pair of n1010 appliances in an HA pair. The redundancy is working as expected. I have an existing virtual-service-blade configured and enabled, which is operating as expected in an HA mode. When I attempt to build a second virtual-service-blade with a unique svs domain number, HA never establishes. Both virtual-service-blades are configured in an L3 mode. Both use the same vlan for control and packet interfaces. Both virtual-service-blades have management interfaces configured in the same subnet. I am not sure why the second virtual service blade is failing to establish HA.
Note that the vsb failing to establish HA is v1ksdc04.
Relevant code from the n1010
virtual-service-blade SDC-UCS01
  virtual-service-blade-type name VSM-1.2
  interface control vlan 480
  interface packet vlan 480
  ramsize 2048
  disksize 3
  numcpu 1
  cookie 199249335
  no shutdown primary
  no shutdown secondary
interface VsbEthernet1/1
interface VsbEthernet1/2
interface VsbEthernet1/3
virtual-service-blade v1ksdc04
  ramsize 2048
  disksize 3
  numcpu 1
  cookie 824653835
  no shutdown
interface VsbEthernet2/1
interface VsbEthernet2/2
interface VsbEthernet2/3
svs-domain
  domain id 2
  control vlan 480
  management vlan 480
  svs mode L2
Relevant code from the vsb that is functioning as expected:
svs-domain
  domain id 1000
  control vlan 480
  packet vlan 480
  svs mode L3 interface mgmt0
v1ksdc01#                                sho redun stat
Redundancy role
      administrative:   secondary
         operational:   secondary
Redundancy mode
      administrative:   HA
         operational:   HA
This supervisor (sup-2)
    Redundancy state:   Active
    Supervisor state:   Active
      Internal state:   Active with HA standby
Other supervisor (sup-1)
    Redundancy state:   Standby
    Supervisor state:   HA standby
      Internal state:   HA standby
System start time:          Sat Sep 14 22:20:57 2013
System uptime:              190 days, 7 hours, 10 minutes, 19 seconds
Kernel uptime:              190 days, 6 hours, 51 minutes, 56 seconds
Active supervisor uptime:   190 days, 7 hours, 9 minutes, 35 seconds
v1ksdc01# sh mod
Mod  Ports  Module-Type                       Model               Status
1    0      Virtual Supervisor Module         Nexus1000V          ha-standby
2    0      Virtual Supervisor Module         Nexus1000V          active *
3    332    Virtual Ethernet Module           NA                  ok
4    332    Virtual Ethernet Module           NA                  ok
5    332    Virtual Ethernet Module           NA                  ok
6    332    Virtual Ethernet Module           NA                  ok
7    332    Virtual Ethernet Module           NA                  ok
8    332    Virtual Ethernet Module           NA                  ok
Mod  Sw                  Hw
1    4.2(1)SV2(2.1)      0.0
2    4.2(1)SV2(2.1)      0.0
3    4.2(1)SV2(2.1)      VMware ESXi 5.1.0 Releasebuild-1312873 (3.1)
4    4.2(1)SV2(2.1)      VMware ESXi 5.1.0 Releasebuild-1312873 (3.1)
5    4.2(1)SV2(2.1)      VMware ESXi 5.1.0 Releasebuild-1312873 (3.1)
6    4.2(1)SV2(2.1)      VMware ESXi 5.1.0 Releasebuild-1312873 (3.1)
7    4.2(1)SV2(2.1)      VMware ESXi 5.1.0 Releasebuild-1312873 (3.1)
8    4.2(1)SV2(2.1)      VMware ESXi 5.1.0 Releasebuild-1312873 (3.1)
Mod  Server-IP        Server-UUID                           Server-Name
1    151.171.106.43   NA                                    NA
2    151.171.106.43   NA                                    NA
3    151.171.97.238   262e7161-f008-e311-0000-000000000003  shc003a.servers.chrysler.com
4    151.171.97.237   262e7161-f008-e311-0000-000000000006  shc003b.servers.chrysler.com
5    151.171.97.236   262e7161-f008-e311-0000-000000000002  shc003c.servers.chrysler.com
6    151.171.97.235   262e7161-f008-e311-0000-000000000005  shc003d.servers.chrysler.com
7    151.171.97.234   262e7161-f008-e311-0000-000000000001  shc003e.servers.chrysler.com
8    151.171.97.233   262e7161-f008-e311-0000-000000000004  shc003f.servers.chrysler.com
* this terminal session
Relevant code from the vwb that is not establishing HA:
svs-domain
  domain id 1004
  control vlan 480
  packet vlan 480
v1ksdc04#    sho redun stat
Redundancy role
      administrative:   primary
         operational:   primary
Redundancy mode
      administrative:   HA
         operational:   None
This supervisor (sup-1)
      Internal state:   Active with warm standby
Other supervisor (sup-2)
Error in getting supervisor and internal state of other supervisor.
System start time:          Mon Mar 24 05:03:14 2014
System uptime:              0 days, 0 hours, 32 minutes, 12 seconds
Kernel uptime:              0 days, 0 hours, 32 minutes, 47 seconds
Active supervisor uptime:   0 days, 0 hours, 31 minutes, 38 seconds
v1ksdc04# sho mod
1    0      Virtual Supervisor Module         Nexus1000V          active *
2    0      Virtual Supervisor Module                             powered-up
Mod  Sw                  Hw
1    151.171.106.144  NA                                    NA
I am not certain why there is an error in getting the supervisor and internal state of the secondary supervisor. Any help would be greatly appreciated.
1 REPLY
Hi,'Active with warm standby'
'Active with warm standby' means that the VSB sees the other VSB on the management VLAN but not the control VLAN. So you would want to trace the control VLAN between these VSBs and verify that it is end to end.
HTH,
Joe
59
