vNIC Rate Limiting option
we are using Cisco UCS C220M3 with VIC 1225 and Nexus 5548UP. Creating vethernet with autocreate works fine. Now we need to rate Limit the nics or build "smaller" nics than 10 GIG using Adapter Fex.
In the Properties of the vnic there are the rate-Limit fields, but they are set as "n/a". Is there any way to build some kind of real virtual GE or FE Cards or do I have to use Qos to get this running?
Thanks in advance,
Andreas
Everyone's tags (1)
1 ACCEPTED SOLUTION
  Kurti, this may help.
Kurti, this may help. starting on Page 5
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/gui/config/guide/1-4-1/b_Cisco_UCS_C-Series_GUI_Configuration_Guide_141/b_Cisco_UCS_C-Series_GUI_Configuration_Guide_141_chapter_01001.pdf
1 REPLY
30
