What is the difference between UCS-SD-16G and UCS-SD-16G= ?
I have some Cisco B200 m3 blades and will be installing some 16GB SD cards in them.  The documentation says that I need UCS-SD-16G cards, but I received cards that say UCS-SD-16G= .  Does anyone know what, if any, difference the '=' makes?  Are they the same card?  I have to make a large purchase of these cards and want to make sure these are the correct type before ordering.  Thanks
1 ACCEPTED SOLUTION
Hi @EBendixen,They are the
Hi @
They are the same type of cards and are supported equal. The main difference is that:
  • : are blank cards. The required image for the server can be downloaded to the card
  • are cards that come with the image for the server
You can purchase the cards with this in mind. All depends on you need if you already have the server image.
Rgrds,
Martin, IT Specialist
Super Bronze
DisclaimerThe Author of this
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I believe the "=" suffix indicates "spare" part.
Hi @
Rgrds,
Thanks so much for your quick
Thanks so much for your quick reply.
You are welcome! It's a
You are welcome! It's a pleasure to help!
Rgrds,
203
