01-23-2012 12:44 PM - edited 03-01-2019 10:14 AM
I am planning to deploy UCS in the next month or so. It sounds like each UCS chassis requires four L6-20 receptacles.
And we're getting two chassis. So I was looking to get a couple of Pulizzi like the onces below. Anyone prefer another
type for better managability or other reasons? Also - is the L6-20 the only power option for the UCS? Thanks.
http://powerquality.eaton.com/ePDU-LPC208-2P.aspx?cx=3
Solved! Go to Solution.
01-23-2012 12:49 PM
There is a 110 plug into a specialized PDU in the rack. Check with your Cisco rep for the part number - it works great. We deployed approximately 100 chassis and this worked very well.
Linda
01-23-2012 12:49 PM
Linda
01-24-2012 08:47 AM
I used to be an APC guy, but really liking this company these days http://www.servertech.com/products/pops-per-outlet-power-sensing/pops-switched-cwg-30vd-vy-3ph-20-30a-busway-24xc13-6xc19-with-pips
You can monitor and admin Much Better, and these PDU's can be set to turn off during thermal events.
Craig
01-25-2012 05:37 AM
Does this PDU work in most standard cabinets, like an APC?
