1760V FXO Ports Stuck with PBX
I have a 1760V with 2FXO, two tel lines are coming from local Tel company. There is no PBX in office
Problem is when people dial the numbers, they find FXO port stuck with the line. PORTS are released only when the CABLE is removed or PORTS are SHUT , NO SHUT
Is there a way to configure the FXO ports in such way that when there is SILENSE in LINE, the ROUTER SHOULD release the PORTS from TEL LINES
So that next time someone want to try, should get the line free
I WOULD BE THANKFUL IF YOU CAN GIVE A REMEDY
I am in difficult situation
I am pasting the display of Router (1760-V)
1760V#sh ru
voice call carrier capacity active
no voice hpi capture buffer
no voice hpi capture destination
fax interface-type fax-mail
mta receive maximum-recipients 0
voice-port 3/0
input gain 8
music-threshold -48
voice-port 3/1
input gain 8
music-threshold -48
mgcp profile default
dial-peer cor custom
dial-peer voice 10 voip
destination-pattern 98T
session target ipv4:x.x.147.40
codec g729r8 bytes 40
dial-peer voice 111 pots
destination-pattern 97T
port 3/0
dial-peer voice 222 pots
port 3/1
1760V#sh call active voice brief
<ID>: <start>hs.<index> +<connect> pid:<peer_id> <dir> <addr> <state>
dur hh:mm:ss tx:<packets>/<bytes> rx:<packets>/<bytes>
IP <ip>:<udp> rtt:<time>ms pl:<play>/<gap>ms lost:<lost>/<early>/<late>
delay:<last>/<min>/<max>ms <codec>
MODEMPASS <method> buf:<fills>/<drains> loss <overall%> <multipkt>/<corrected>
last <buf event time>s dur:<Min>/<Max>s
FR <protocol> [int dlci cid] vad:<y/n> dtmf:<y/n> seq:<y/n>
<codec> (payload size)
ATM <protocol> [int vpi/vci cid] vad:<y/n> dtmf:<y/n> seq:<y/n>
Tele <int>: tx:<tot>/<v>/<fax>ms <codec> noise:<l> acom:<l> i/o:<l>/<l> dBm
MODEMRELAY info:<rcvd>/<sent>/<resent> xid:<rcvd>/<sent> total:<rcvd>/<sent>/<
drops>
speeds(bps): local <rx>/<tx> remote <rx>/<tx>
Proxy <ip>:<audio udp>,<video udp>,<tcp0>,<tcp1>,<tcp2>,<tcp3> endpt: <type>/<m
anf>
bw: <req>/<act> codec: <audio>/<video>
tx: <audio pkts>/<audio bytes>,<video pkts>/<video bytes>,<t120 pkts>/<t120 by
tes>
rx: <audio pkts>/<audio bytes>,<video pkts>/<video bytes>,<t120 pkts>/<t120 byt
es>
Telephony call-legs: 1
SIP call-legs: 0
H323 call-legs: 1
Total call-legs: 2
12A2 : 10030958hs.1 +4342 pid:222 Answer 97T active
dur 00:00:05 tx:188/3760 rx:128/5120
Tele 3/1:134: tx:5140/514/0ms g729r8 noise:0 acom:15 i/0:-22/-19 dBm
12A2 : 10033470hs.1 +1830 pid:10 Originate 980911932071170 active
dur 00:00:05 tx:127/5080 rx:188/3760
IP 217.218.147.40:16654 rtt:466ms pl:650/0ms lost:0/0/0 delay:69/69/70ms g729r8
SIP call-legs: 0
H323 call-legs: 1
Total call-legs: 2
SIP call-legs: 0
H323 call-legs: 1
Total call-legs: 2
GENERIC:
SetupTime=10030958 ms
Index=1
PeerAddress=97T
PeerSubAddress=
PeerId=222
PeerIfIndex=9
LogicalIfIndex=5
ConnectTime=10035300
CallDuration=00:00:25
CallState=4
CallOrigin=2
ChargedUnits=0
InfoType=2
TransmitPackets=1114
TransmitBytes=22280
ReceivePackets=600
ReceiveBytes=22525
TELE:
ConnectionId=[0x969F9329 0xF19211D7 0x80CBAF3B 0x3F3986CB]
IncomingConnectionId=[0x969F9329 0xF19211D7 0x80CBAF3B 0x3F3986CB]
TxDuration=25780 ms
VoiceTxDuration=2275 ms
FaxTxDuration=0 ms
CoderTypeRate=g729r8
NoiseLevel=-67
ACOMLevel=0
OutSignalLevel=-6
InSignalLevel=-8
InfoActivity=2
ERLLevel=15
SessionTarget=
ImgPages=0
CallerName=
CallerIDBlocked=False
OriginalCallingNumber=
OriginalCallingOctet=0x0
OriginalCalledNumber=
OriginalCalledOctet=0x81
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x0
GwCollectedCalledNumber=xxxxxx932071170T
GwReceivedCdn=
GwReceivedCgn=
GwFinalTranslatedCdn=
GwFinalTranslatedCgn=
TranslatedCallingNumber=
TranslatedCallingOctet=0x0
TranslatedCalledNumber=
TranslatedCalledOctet=0x81
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x0
GENERIC:
SetupTime=10033470 ms
Index=1
PeerAddress=xxxxxx932071170
PeerSubAddress=
PeerId=10
PeerIfIndex=7
LogicalIfIndex=0
CallDuration=00:00:27
CallState=4
CallOrigin=1
ChargedUnits=0
InfoType=2
TransmitPackets=643
TransmitBytes=24088
ReceivePackets=1213
ReceiveBytes=24260
VOIP:
ConnectionId[0x969F9329 0xF19211D7 0x80CBAF3B 0x3F3986CB]
IncomingConnectionId[0x969F9329 0xF19211D7 0x80CBAF3B 0x3F3986CB]
RemoteIPAddress=x.x.147.40
RemoteUDPPort=16654
RemoteSignallingIPAddress=x.x.147.40
RemoteSignallingPort=1720
RemoteMediaIPAddress=x.x.147.40
RemoteMediaPort=16654
RoundTripDelay=534 ms
SelectedQoS=best-effort
tx_DtmfRelay=inband-voice
FastConnect=TRUE
AnnexE=FALSE
Separate H245 Connection=FALSE
H245 Tunneling=FALSE
SessionProtocol=cisco
ProtocolCallId=
SessionTarget=ipv4:x.x.147.40
OnTimeRvPlayout=19120
GapFillWithSilence=90 ms
GapFillWithPrediction=190 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=70 ms
LoWaterPlayoutDelay=50 ms
ReceiveDelay=50 ms
LostPackets=1
EarlyPackets=0
LatePackets=0
VAD = enabled
CodecBytes=40
CallerName=
OriginalCalledNumber=xxxxxx932071170
GwReceivedCdn=
GwReceivedCgn=
GkProvidedE164Cdn=
GkProvidedE164Cgn=
GwFinalTranslatedCdn=xxxxxx932071170
TranslatedCalledNumber=xxxxxx932071170
Username=Telephony call-legs: 1
SIP call-legs: 0
H323 call-legs: 1
Total call-legs: 2
1760V#sh call active voice id 1
SIP call-legs: 0
H323 call-legs: 1
Total call-legs: 2
SIP call-legs: 0
H323 call-legs: 1
Total call-legs: 2
1760V#sh call active voice compact
G<id> A/O FAX T<sec> Codec type Peer Address IP R<ip>:<udp>
Total call-legs: 2
G12A2 ANS T59 g729r8 TELE P97T
G12A2 ORG T59 g729r8 VOIP Pxxxxxx932071170 x.x.147.40:16654
Re: 1760V FXO Ports Stuck with PBX
I would be thankful upon +ve response from any of my friends
Atif
You are running into FXO supervisory disconnect issue. The following URL will help you inderstand the problem:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Some other workarounds are also pointed in the following URL:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a00801601ac.html
I hope that helps.
Javed
Hi, you should review the cabling from telco this has to be like this
1234 pins
-+ this is the right order of the polarity, although you need to ground the chasis of the router.
and review the disconnect supervision command for your zone.
suerte!!
152
