6945 will not register in SRST.
Nancy Jazrawi
I am running IOS 15.1M which does not support 6945 phone in SRST.
I know if I upgrade to IOS 15.2, the 6945 would be supported.
However, I cannot change the IOS at this time.
Is there a workaround I can do to get the 6945 to work in SRST when running the current IOS?
Any advice and/or direction would be greatly appreciated.
Thank you,
Nancy
Jorge Armijo
Level 4
Level 4
If the Phone is not supported on the current IOS, there isn't way to do it, if someone give you a workaround, you'll have a bad time with that Phone in SRST.
Better to go save and upgrade IOS.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
