Community Member
abnormal disconnect when calls forwarded to vm on busy or noan
Avaya S8700 <> h.323 trunk group <> CCME 4.0.3
Inbound calls over IP trunk disconnect when forwarded to AIM-CUE upon noan or busy. No problems observed when call is answered. Nor are there issues with inbound calls to same number placed over POTS line. Has anybody experienced similar issues with Avaya / Cisco operability?
Hall of Fame Super Red
Re: abnormal disconnect when calls forwarded to vm on busy or no
Hi Thomas,
I am pretty sure that this a transcoding issue,especially seeing that calls routed through the POTS line are working properly have a look;
Codecs and Transcoding
Cisco Unity Express supports only G.711 voice streams, so all calls made into the system (including those from IP phones, PSTN gateway ports and any other VoIP equipment in your network) must use G.711 if they enter the AA or voice mail pilot numbers that terminate on Cisco Unity Express.
If you require that G.729A calls traverse IP segments of your network between sites, and that these calls forward or dial direct into Cisco Unity Express AA or voice mail, then you must use a transcoding resource collocated with Cisco Unity Express to change the voice stream from G.729A to G.711 before the voice stream enters the AA or voice mail pilot numbers.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_implementation_design_guide_chapter09186a00804993c0.html#wp1011776
Hope this helps!
Rob
Please remember to rate helpful posts.....
Community Member
Rob,
I think your suggestion is right on. Now as I understand the documentation, I can use my PVDM2-32 to do my transcoding. As of now, I've only got five POTS lines which equates to five G.711 channels. My interoffice IP trunk group consists of eight G.729 channels. So I'm using roughly 2/3 of my available PVDM2-32 resources. Is the configuration as simple as what I've depicted below? Or am I missing something? I'm going to try this when I get back in the office on Monday.
Thom
voice-card 0
dsp service dspfarm
exit
dspfarm profile 10 transcode
codec g711ulaw
codec g729abr8
codec g729ar8
associate application SCCP
maximum sessions 8
Hi Thomas,
You are right on track here! Have a read of this good Transcoding doc. Get your DSP resources set up and you should be good to go.
You will have to use transcoding resources collocated with Cisco Unity Express to change the voice stream from G.729A to G.711 before the voice stream enters the AA or voice mail pilot numbers.
Cisco CallManager Express 3.3: Transcoding Between G.729 and G.711
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00804ad867.html#wp2234735
Hope this helps!
Rob
Also a couple more things to remember in this config. Make sure under the Telephony Service that a call forward pattern .T is added. I've seen in CM 3.3 if this isn't added the call will not be successful.
191
