Community Member
analog to analog phone call through AS5350
I have AS5350 in the main site and noo cisco voice gateways at the remote site with analog phones, AS5350 is connected to PBX through E1 R2, call is successful between main and remote but not from remote to remote.
Attached the configuration of the AS5350.
Hall of Fame Super Gold
Re: analog to analog phone call through AS5350
can you configure the remotes so that they call each other directly and not via as5350 ?
That would be the best option.
Community Member
Dear p.bevilacqua,
Actually the topology of the network as Hub and spoke, there is no connection directly between remote sites, the connection only through AS5350.
even in hub and spoke topologies, you can configure IP routing so that each remote can ping and talk to each remote. That would be the best option.
Else, you need to configure the As5350 as an IP-to-IP GW, with the appropriate command and required image.
122
