call fallback active problem
PBXA-PRI-2851---IP-----2851-PRI--PBXB.
Calls between two PBX are fine with this setup. Then I tested the busyout monitor probe IP, which requires call fallback command, so taht when IP down PBX will re-route call to PSTN automatically. However as soon as I added call fallback active, call not working anymore. Debug voip ccapi inout shows H323call setup just does not receive on the other router at all. Has anybody seen this before?
1 REPLY
Hall of Fame Super Gold
Re: call fallback active problem
have you configured the parameters ?
call fallback threshold delay loss
call fallback threshold icpif
These have no default values so I guess unless configured properly the effect would be to block all calls.
190
