ccme T1 Connection
i have one t1 connection and Toll by pass is already configured in the ccme .
i would like to add one more t1 and segregate the toll by pass calls only through new t1 .
is it possible and what hardware is needed for this and do we require more dsp resources for this ?
1 REPLY
Re: ccme T1 Connection
Yes, this is easily done. On your toll bypass dial peers just make sure that the destination port is the one you're wanting to use.
If you are using another PRI, you will want additional DSPs, correct. The DSP calculator is helpful for calculating this: http://www.cisco.com/cgi-bin/Support/DSP/cisco_prodsel.pl
hth,
nick
144
