Cisco 1760 with VIC-4FXS/DID Problem
I've installed cisco 1760 with ViC-4FXS/DID (router information as below) and I found DSP problem. Now I've to reload the router then I can use for awhile but It'll happend again.
Many thanks for any ideas.
----show log ----------
.Mar 2 13:10:07.301: %DSM-3-DSP_TIMEOUT: DSP timeout on channel 2/1 (35), event 0x59: DSP ID=0x1: DSP error stats, dsprm info(mips_released=0, grp=0, dsp=0, bsp_port=0, bsp_ts=0, vic_port=1, vic_ts=4)
.Mar 2 13:10:07.301: %IPM_C54X-3-HOST_XMIT_BLOCKED: Host is unable to transmit packets to DSP 0
.Mar 2 13:10:27.249: %IPM_C54X-1-DSP_TIMEOUT: dsp 0 NOT RESPONDING.
.Mar 2 13:10:28.525: ASSERTION FAILED: file "../src-m860-les/if_ipm_c54x_idma.c", line 660
.Mar 2 13:10:57.217: %IPM_C54X-1-DSP_TIMEOUT: dsp 0 NOT RESPONDING.
.Mar 2 13:10:59.289: %LINK-3-UPDOWN: Interface Foreign Exchange Station with Direct Inward Dialing (FXS-DID) 2/0, changed state to up
.Mar 2 13:10:59.289: %LINK-3-UPDOWN: Interface Foreign Exchange Station with Direct Inward Dialing (FXS-DID) 2/1, changed state to up
.Mar 2 13:10:59.293: %LINK-3-UPDOWN: Interface Foreign Exchange Station with Direct Inward Dialing (FXS-DID) 2/2, changed state to up
.Mar 2 13:11:00.045: %LINK-3-UPDOWN: Interface Foreign Exchange Station with Direct Inward Dialing (FXS-DID) 2/3, changed state to up
------------------ show voice dsp ------------------
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
C549 000 00 g711ulaw Idle Idle 0 0 2/0 NA 0 1250/779
C549 000 01 g711ulaw Idle Idle 0 0 2/1 NA 0 2831/3233
C549 000 02 g711ulaw Idle Idle 0 0 2/2 NA 0 5937/6704
C549 000 03 g711ulaw Idle Idle 0 0 2/3 NA 0 8240/8732
Active Voice Call details
Current total analog signalling channels: 4
Current max allowed digital timeslot for voice: 0
Current number of DSP group: 1
Group 0:
Current allocated analog signalling channels: 4
Current free analog signalling channels: 0
Current allocated digital signalling channels: 0
Current free digital signalling channels: 0
Port(s) served: 2/0 2/1 2/2 2/3
Current Available MIPS: 100
SPMM DSPRM State Image D-sig D-sig A-sig A-sig Mips Voice/Xcode
Dsp Dsp allocate free allocate free Free Chan
0/0 0 DOWN FIXMC 0 0 4 0 100 0
------------------ show version ------------------
IOS (tm) C1700 Software (C1700-SV3Y-M), Version 12.2(15)ZL, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Synched to version 12.3(0.1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 13-Jun-03 09:55 by ealyon
Image text-base: 0x80008120, data-base: 0x811BA6D8
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-SV3Y-M), Version 12.2(15)ZL, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
VR340 uptime is 32 minutes
System returned to ROM by reload
System restarted at 17:59:16 UTC Tue Dec 23 2003
System image file is "flash:c1700-sv3y-mz.122-15.ZL.bin"
cisco 1760 (MPC860P) processor (revision 0x500) with 83968K/14336K bytes of memory.
Processor board ID FOC074503QS (1387297808), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
4 Voice FXS interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
------------------ show running-config ------------------
Building configuration...
Current configuration : 3726 bytes
! Last configuration change at 18:25:04 UTC Tue Dec 23 2003
! NVRAM config last updated at 18:05:42 UTC Tue Dec 23 2003
version 12.2
hostname xxx
logging queue-limit 100
enable password <removed>
voice-card 2
ip subnet-zero
no ip domain lookup
ip cef
no voice hpi capture buffer
no voice hpi capture destination
interface FastEthernet0/0
ip address 192.168.3.254 255.255.255.0
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0/0.200 point-to-point
ip address 10.10.100.22 255.255.255.252
frame-relay interface-dlci 200 CISCO
class 128k
vofr data 4 call-control 5
interface Serial0/1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.100.21
no ip http server
map-class frame-relay 128k
frame-relay cir 128000
frame-relay bc 1000
frame-relay be 0
frame-relay mincir 64000
frame-relay adaptive-shaping becn
frame-relay fair-queue
frame-relay voice bandwidth 40000
frame-relay fragment 160
snmp-server community <removed> RO
snmp-server enable traps tty
voice-port 2/0
cptone TH
timeouts ringing 30
voice-port 2/1
cptone TH
timeouts ringing 30
voice-port 2/2
cptone TH
timeouts ringing 30
voice-port 2/3
cptone TH
timeouts ringing 30
dial-peer cor custom
dial-peer voice 601 pots
destination-pattern 340
port 2/0
dial-peer voice 602 pots
port 2/1
dial-peer voice 603 pots
port 2/2
dial-peer voice 200 vofr
destination-pattern ...
session target Serial0/0 200
dtmf-relay
fax rate 9600
no vad
dial-peer voice 604 pots
port 2/3
num-exp 205 50088205
num-exp 206 50088206
line con 0
password <removed>
login
line aux 0
password <removed>
line vty 0 4
password <removed>
login
no scheduler allocate
end
Silver
Re: Cisco 1760 with VIC-4FXS/DID Problem
DSP timeouts like this generally indicate a software bug. Since the unit works for a while then fails, I don't think tis is hardware related. There are a lot of DSP related bugs that give this kind of message, so what I suggest is to load a later release of code - I would suggest 12.3.5a IP voice plus feature set. This should have support for the VIC4FXS card.
Please give this a try and see how it goes.
Thank you very much, It's working fine for few day.
493
