Cisco 2600 FXS BUSY tone tuning
Does anyone here have any experience tuning the busy tone duration of the FXS port? I tried searching the docs but I cannot find anything specific. I have the fxs hooked up to an fxs/fxo converter that takes the fxs's busytone and tunes the converter so the fxs port can be used like an fxo port for outside calls. The FXO/FXS converter uses ITU compliant busy tones. I have the unit working but after a call is made the unit does not release the port because it does not properly detect the fxs's busy tone either quickly enough or long enough. For those interested the FXO/FXS converter is located at www.pcphoneline.com and it is priced decently..
Any tips or ideas would be appreciated..
Regards...
1 REPLY
Re: Cisco 2600 FXS BUSY tone tuning
Hi, did you enable the battery reversal of that port?
313
