Bronze
Cisco 3526 PRI gateway and Connection to PBX
Is it possible to connect a 3526 PRI gateway directly to PBX .I read the release notes on 3526 and it says we can.I am not familiar with video stuff much.If any one can explain the working it will be really helpful.
Thanks.
1 REPLY
Re: Cisco 3526 PRI gateway and Connection to PBX
Yes... A 3526 can be hooked to a PBX. The PBX needs to provide network-side signalling to the 3526. The 3526 supports a number of PRI signalling types including 5ESS, 4ESS, NI2, DMS100, etc... so it should be pretty flexible in working with various PBXs. Note, that you may also need a CSU. Hope this helps
354
