Cisco 3750 doesnt take power inline auto!
Im trying to configure power over Ethernet for my cisco ip phone. My switch is 3750.
framedrelay(config-if)#power inline ?
auto Automatically detect and power inline devices
never Never apply inline power
framedrelay(config-if)#power inline a
framedrelay(config-if)#power inline auto
Command rejected: Not a Inline Power supported port.
I dont know why it isnt working. If its the version
framedrelay#show version
IOS (tm) C3750 Software (C3750-I5-M), Version 12.1(14)EA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 22-Jul-03 13:17 by antonino
Image text-base: 0x00003000, data-base: 0x008F0CF8
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(11r)AX, RELEASE SOFTWARE (fc1)
framedrelay uptime is 1 day, 5 hours, 1 minute
System image file is "flash:c3750-i5-mz.121.14-EA1/c3750-i5-mz.121.14-EA1.bin"
cisco WS-C3750G-24TS (PowerPC405) processor (revision B0) with 120822K/10240K bytes of memory.
Processor board ID CAT0730X007
Last reset from power-on
Bridging software.
4 Virtual Ethernet/IEEE 802.3 interface(s)
28 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:0D:65:66:E7:80
Motherboard assembly number : 73-7058-09
Power supply part number : 341-0045-01
Motherboard serial number : CAT0729003G
Power supply serial number : LIT0723009B
Model revision number : B0
Motherboard revision number : A0
Model number : WS-C3750G-24TS-E
System serial number : CAT0730X007
Switch Ports Model SW Version SW Image
* 1 28 WS-C3750G-24TS 12.1(14)EA1 C3750-I5-M
Configuration register is 0xF
Kindly help.
Sylvester!
Re: Cisco 3750 doesnt take power inline auto!
Your model switch does not support the Power over Ethernet feature. Please take note of the model number: WS-C3750G-24TS.
The equivalent model switch which does support POE is the WS-C3750G-24PS. Notice the model number ends with PS instead of TS.
Check thefollowing datasheet for a description of all the various models:
http://cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/product_data_sheet0900aecd80371991.html
I hope this helps.
Bill.
Thanks Bill,
Cheers
2022
