Connection Plar on FXS
Hi all,
I have the folowing situation:
I have configure a 2821 mgcp gateway on CM 5.1.2 with EVM-8FXS/DID. On the fxs I only have configure a CSS and the prefix field. Afther i pick up the fxs phone the CM dials the prefix number and the is made sucessufly. If for same reason the called number disconect the call and the calling phone stays off-hook the fxs phone keeps calling the prefix dn every 3 seconds. Is there any way for the callmanager not do dial the prefix dn from the hot line if the hot-line stays off-hook.
Re: Connection Plar on FXS
That is how its designed. Unless the fxs port goes on hook it will keep placing the calls. There is a feature in the VG248 that says
Port busy signaling invoked softkey event
which stops the vg to place a call unless a softkey event end call is received.
That feature is available on mgcp gateways ex:2821
586
