DHCP for Voice and Data VLAN's
We are configuring a Cat4500 to support voice and data on the same switch port. The 4500 must provide separate dhcp pools for the voice and data vlans:
ip dhcp pool Data
network 192.168.101.0 255.255.255.0
default-router 192.168.101.1
ip dhcp pool Nortel-IP-Phones
network 192.168.120.0 255.255.255.0
default-router 192.168.120.1
int vlan101
ip address 192.168.101.0 255.255.255.0
int vlan120
ip address 192.168.120.0 255.255.255.0
Would the following port configuration allow the IP phones, and the workstations attached to them, to pick up an IP address from the correct DHCP pool?
interface fas4/1
switchport mode trunk
switchport nonegotiate
switchport voice vlan 120
spanning-tree portfast
spanning-tree bpduguard enable
Thanks in advance
1 REPLY
Re: DHCP for Voice and Data VLAN's
this depends on the configuration of your telephones. in case they are trunking for VLANs 101 and 120 it should work.
Just one more thing: the ip addresses on the VLANs 101 and 120 should be .1 and not .0, but I assume this is a typo in the post.
Hope this helps
Martin
497
