Dial-peer not matching ?!?! strange. help please!!!
Hello there,
I am having problems on matching my outgoing dial peer, the one i Dont want takes over you may say.
i dial to 8018xxx33 would like dial peer 8187061 to be the one, as a better destination pattern, yet dial peer 22 takes over out of the blue.
not sure why this is happening but i am open to ideas.
the call flow i would like is:
dial peer 1001 (in call) -> dial peer 8187061 (for the h323).
but i am getting 1001 -> 22
0xB4983 2FD9 0x657381B4 6/3:D.0 3004/4 8018xxx33 g711ulaw 1001/22
and here are the dial peers:
dial-peer voice 1001 pots
trunkgroup 40
corlist incoming listNoANI
description Incoming Test line for Cisco1 slot/port/ds1/chan=6/3 400hz
application au_ani_400
incoming called-number 866xxx435
and the problematic ones:
dial-peer voice 8187061 voip
description Outgoing Test for VoIP International - Delete after test
settle-call
destination-pattern 8018xxx33
voice-class codec 69
voice-class h323 1
session target ipv4:x.x.x.x
dtmf-relay rtp-nte h245-signal h245-alphanumeric
dial-peer voice 22 voip
corlist outgoing listNoANI
destination-pattern [2-8].........
session protocol sipv2
session target ipv4:x.x.x.x.x
codec g711ulaw
clid network-number 70244xxxxx
any ideas? may it be the Corlist that is taking over?
dial peer 8187061 is the longest match that i am dialing to.
thanks in advance,
J.
Hall of Fame Super Gold
Re: Dial-peer not matching ?!?! strange. help please!!!
What application au_ani_400 does?
A incoming DP with application (currently termed "service") should in fact end there without further processing.
Remember, you can always testoutgoing DP with "show dialplan number XXX "
Hey Boss,
Thanks for the advice, it was actually the corlist that took preference over the dial peer matching.
the command you gave me was GOLD thanks you.
i am now getting a fast busy signal on the line, are there any good debug command that i may run to check the h323 call on this dial peer.
Jonathan
Strange it was the corlist, these are supposed to only block a DP, not change priorities.
You can do some debug cch323 if you feel like looking into a bunch of cryptic output. Else, debug ccapi, debug dialpeer are often useful, but still too verbose for my taste.
195
