difference between voice gateways and gatekeeper
Could someone kindly explain (or provide a url link) the main difference between voice gateways and a gatekeepers ?
2 ACCEPTED SOLUTIONS
Silver
Re: difference between voice gateways and gatekeeper
Your best source of information is the Cisco Press book "Cisco Voice Gateways and Gatekeepers (GWGK)" which explains these 2 in more detail. I've included the information to help..
The Role of Voice Gateways:
In a VoIP environment, voice gateways are the interface between a VoIP network and the public switched telephone network (PSTN), a private branch exchange (PBX), or analog devices such as fax machines. In its simplest form, a voice gateway has an IP interface and a legacy telephone interface, and it handles the many tasks involved in translating between transmission formats and protocols.
At least one gateway is an essential part of any IP telephony network that interacts with the PSTN or with analog devices. In addition, when gateways are properly configured, many can take over for a Cisco CallManager when it is unreachable.
The gateway allows communication between the two networks by performing tasks such as these:
Interfacing with the IP network and the PSTN or PBX.
Supporting IP call control protocols, in addition to time-division multiplexing (TDM) call control protocols.
Performing call setup and teardown for calls between the VoIP and PSTN networks by terminating and reoriginating the call media and signaling.
Providing supplementary services, such as call hold and transfer.
Relaying dual tone multifrequency (DTMF) tones.
Supporting analog fax and modems over the IP network.
In a Cisco CallManager network, a gateway also needs to do the following:
- Support CallManager redundancy by rehoming to alternate CallManagers.
- Support call survivability when no CallManager is available.
Gateways communicate with other gateways, gatekeepers, their endpoints, or their call control agents, such as Cisco CallManager or a PBX.
The following are the protocols that Cisco gateways use for voice signaling and media:
Media Gateway Control Protocol (MGCP)
H.323
Session Initiation Protocol (SIP)
Skinny Client Control Protocol (SCCP)
Real-Time Transport Protocol (RTP)
The Role of Voice Gatekeepers:
Gatekeepers help VoIP networks scale to large sizes. Companies that have geographically dispersed voice networks, or networks that have become so large that they are unwieldy, might opt to segment their network. In a CallManager network, you can create multiple clusters. In that case, you would need to configure a full mesh of connections over the IP WAN to link all the segments or clusters. You would need to configure dial information for every remote location on every gateway and CallManager cluster.
A better alternative is to use gatekeepers. In a network that has gatekeepers, trunks are needed only to the gatekeeper, and the gatekeeper maintains remote endpoint information.
When you use gatekeepers, gateways and CallManagers register with their gatekeeper. Gatekeepers divide the network into "zones," or groups of devices that register with a particular gatekeeper.
When an H.323 gateway receives a call that is destined to a remote phone, it queries the gatekeeper for the location of the endpoint.
If the call is destined for a different zone, you can configure the gatekeeper to allow it only if sufficient bandwidth is available. In more complex networks, you can use a Directory gatekeeper to maintain information about all the zones.
You can configure Cisco routers with the appropriate Cisco IOS as H.323 gatekeepers.
Please rate useful posts...
Silver
Gatekeepers specifically H323
Gateways can be include MGCP, H323 or SCCP..
Silver
H.323
Is it applicable even using MGCP gateways ? or gatekeeper functions only with H.323 gateways ?
Silver
Hi tim.giles
Can u plz tell the basic difference between these two..?
What is the difference between their usage...??
Thanks and R's
Harish
Blue
Gateways are used to connect to PSTN world by using either MGCP/H.323 or SIP protocol via, PRI/BRI or analog ports. While Gatekeeper has following functionality
Gatekeepers   reduce configuration overhead by eliminating the need to configure a   separate H.323 device for each remote Cisco Unified Communications   Manager that is connected to the IP WAN.
A   gatekeeper can determine the IP addresses of devices that are   registered with it, or you can enter the IP addresses explicitly.
The gatekeeper supports the H.323 protocol and uses the H.225 protocol to make calls.
The gatekeeper can perform basic call routing in addition to call admission control.
You can connect up to 100 Cisco Unified Communications Manager clusters to a single gatekeeper.
Ronak Patel
Please rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Silver
Hi Harish,
Basically, gateways facilitate comms between POTS and VoIP - it's an entry point which converts one type of traffic into another (analog\digital to IP). Think of it as a translator..
The gatekeeper (H323) is an optional component (can be hardware or software), however when it's included it becomes the central administrative point. Think of it as it's own entity which maintains remote endpoint information for it's own area. A trunk link then connects it back to the CallManager.
Gatekeepers help VoIP networks scale to much larger sizes..
Hope this helps..
Tim
I have LG ARIA exchanges with analogue phones which in turn is connected on E1 port on CISCO 7206 VXR router at 17 locations. These 17 locations also has IP phones which are registered on call manager 5.1. I have a voice gateway with 1 PVDM2-64 and one PVDM2-32. These 17 locations get connected on a central location where the call manager is located. How do I make my IP phones and analogue phones communicate with each other ?
Ayan
hello
do u have any solution to my problem
19513
