Disabling H.264 for VT Advantage (in Callmanager/regedit)
Does anyone know how to disable H.264 video calls from within Callmanager 5.1? Or via a registry setting?
I've just deployed 30+ cameras and software, but have now found an issue with our Codian MCU and H.264 - we get 1 way video.
The fault seems to be in the Codian, but in the mean time - I really need to get H.264 turned off - and I'm trying to avoid a series of uninstalls and reinstalls, to get to a setup as documented here:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_ipphon/english/ipcvl/admin2_0/vinstall.htm#wp1055106
Anyone got a quick regedit hack that will achieve this? or a Callmanager setting?
  • Video Over IP
Re: Disabling H.264 for VT Advantage (in Callmanager/regedit)
I think this will work:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\Cisco Unified Video Advantage]
"VideoCodec"="H.263"
You must close VTA, apply registry change, then restart VTA. Of course, fiddling with the registry - do so at your own risk.
Can you try editing registry under this key:
There is entry "VideoCodec" and by default it's set to ALL
Can you try to change it to:
H.263
249
