Display IP of incoming calls on caller ID
Would it be possible to display the IP address of an incoming caller on my caller ID?
The calls are from 7931s at remote locations to another 7931 on my desk.
Re: Display IP of incoming calls on caller ID
You may only set IP as a caller ID. It will work only if IP of the phone is fixed not DHCP configured.
Nothing will be using DHCP, all statics. Thanks for the reply.
What I have is a series of workstations that get connectivity from the 7931's. The phones have a seperate IP, its the IP of the workstation behind the phone that I was wanting to display on the caller ID of my phone. I can clarify further if anyone needs more detail.
Thanks.
159
