Community Member
dual power
I would like to confirm the dual power of 7301. There is only one power supply active even I connect two power cables to the router.
If there is no electricity to active power supply, the second power supply will take care the role to supply electricity.
Is it correct?
rgds
1 REPLY
Silver
Re: dual power
The chassis supports both single and dual power supplies (AC or DC). "Power supply" slot is a "port adapter" slot. 7301 power supplies are not modular (come as fixed configurations upon purchase as single or dual).
http://www.cisco.com/en/US/prod/collateral/routers/ps352/ps4972/product_data_sheet09186a008014611a.html
http://www.cisco.com/en/US/docs/routers/7300/install_and_upgrade/7301/7301_quick_start_guide/5341Q.html#wp34747
145
