Community Member
Fast busy problem with h323
I have attached a drawing of the network and show run from CCME. But the jist of the problem is that I can call from phone 6000 using CCM to phone 2222 using CCME with no problems. As soon as I turn that around and dial 6000 from phone 2222 I get a fast busy. I can ping everythig and when I did debug dialpeer I see that it is matching the correct dial peer. Plus I never see the call get to CCM. The traces are empty and yes they are turned on to detail. On the 2222 phone when I dial 6000 I see the follwoing error. "Unknown Number". Any Ideas as to what is going on?
Community Member
Re: Fast busy problem with h323
Opps here is the attachments. sorry
Community Member
you do have route patterns in the CCM pointed at CCME ? Also I think you can get rid of the intercluster trunk configuration if being used and add the CCME as h323 gtwy. Other post also looks correct....
Community Member
1. Check the configuration of CCM H.323 trunk to CCME (inboud CSS).
2. I see that ip source address for CCME is on DATA subnet. Try to change it to VOICE subnet.
3. Also, configure h.323 interface on CCME
interface FastEthernet0/1.301
h323-gateway voip interface
h323-gateway voip bind srcaddr
4. EIGRP confiuration on CCME:
you have particular subnets but you did auto-summary? why? configure no auto-summary.
also, do you have network on CCME side?
anyway, if you can ping everything than it may be ok but still check with PC in VOICE VLAN to ping CCM and phone 6000 IP address.
hope this helps...
let us know if not :)
Community Member
Here's something else I missed, I believe the default codec for a voip dial-peer is g729 try adding something like codec g711u
to the voip peer
Community Member
Make sure you add these commands to the express.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
