FXS FXO plar problem
I have VOIP configured with FXO and FXS,now I can plar from FXO to FXS but when I plar from FXS to FXO I can call in a few second and it will disconnect line.please sugguest me.
FXS config
call rsvp-sync
voice-port 2/0
input gain 8
description 8001
voice-port 2/1
input gain 8
description 8002
mgcp profile default
dial-peer cor custom
dial-peer voice 8001 pots
destination-pattern 8001
port 2/0
dial-peer voice 8002 pots
destination-pattern 8002
port 2/1
dial-peer voice 7001 voip
destination-pattern 900.
session target ipv4:10.10.11.2
codec g729r8 bytes 40
ip qos dscp cs5 media
FXO Config
call rsvp-sync
voice-port 2/0
input gain 8
connection plar 8001
voice-port 2/1
input gain 8
connection plar 8002
dial-peer voice 9001 pots
destination-pattern 9001
port 2/0
dial-peer voice 9002 pots
destination-pattern 9002
port 2/1
dial-peer voice 9003 voip
destination-pattern 800.
session target ipv4:10.10.11.1
When I debug voip ccapi error I see this message
*Mar 1 04:30:10.561: //211/8E60753E81AC/SSAPP:9003:93/ssaConfCreateDoneAlert: O
ther call leg not found
*Mar 1 04:31:41.021: //211/8E60753E81AC/CCAPI/cc_api_call_disconnect_done: caus
e=16,retry=0,vcCauseCode=0
*Mar 1 04:31:41.021: //212/8E60753E81AC/CCAPI/ccGetCallActiveByCallID: cc_spi_c
all_get() returned -7. (setup_time=0x18BC3F, index=0x1)
*Mar 1 04:31:41.029: //212/8E60753E81AC/CCAPI/cc_api_call_disconnect_done: caus
*Mar 1 04:31:55.806: //212/8E60753E81AC/SSAPP:9003:93/ssaConfCreateDoneAlert: O
Silver
Re: FXS FXO plar problem
Try adding the command 'incoming called-number .' on the VOIP dial peers on each device - it could be the return call is matching on the default dial peer (dial peer 0) , which will try and use G729r8 20 byte packetisation period.
before I config that you suggest,I try to test by connect the phone direct to FXS port.It can use plar
and call doesn't disconnect.It will have problem with plar when FXS use PBX.What is parameter to tuning?How to check it?
Thank you.
in your voice port try adding the caller-id enabled.
and try to take that out the input gain
460
