FXS idle problem
Hi:
I am working with a 2801 series with 12.4(3i) version, this equipment is interacting with a CCM5.
When qe want to use the fax ports(FXS), it works for a while but suddenly it stop to work with no reason, when we hang up the fax (off-hook) there is no tone.
in the router appears this message:
flex_dsprm_tdm_xconn: voice-port(0/0/1), dsp_channel(/0/0/0)
is anybody know how to fix it. I found a bug similar that it but with FXO and i dont use caller-id enable.
regards
Community Member
Re: FXS idle problem
Conditions: With caller-id enable configured on FXO ports, the call will connect, but no audio is heard. When this occurs, the following error message can be seen at debug level:
Jun 20 01:41:15.855: mbrd_e1t1_vic_connect: setup failed
Jun 20 01:41:15.855: flex_dsprm_tdm_xconn: voice-port(0/0/1), dsp_channel (/0/2/0)
Workaround: Disable caller id on the voice-port.
Ringing and Idle Voltages on Cisco FXS Interfaces:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a008011c7f3.shtml
thanks for answer
but, if in the FXS port doesn't have a caller-id enable command, what is the reason of this message.
regards
Hall of Fame Super Gold
Hola,
can you upgrade to 12.4(11)XJ4 and try again ?
270
