FXS PLAR CONFIGURATION HELP.
arellanolouie
The design is like a Private phone line between two site over VOIP network. Im using CCME 7 on both routers.
Private Phone connects to fxs on router and thesame setup on the other site. attached the design diagram and config.
Try to use "connection plar opx" under voice-port on both side. In this way, when the phone become off hook calls automatically the remote extension.
Regards.
hi Daniele,
is this correct Dan,
voice-port 0/3/0
connection plar opx 1111
caller-id enable
it gives an error code 21.
Do you have configured connection plar opx in both sites? Do you have removed connection trunk?
Can you add the output of "debug voice ccapi inout"?
Regards.
