H.323 Gateway Issue?
Hi:
I'm a new coming in the forum. Recently I have met some problems in the situation below:
A CUCM6.0 Server Add a Gateway RouterA,
Another CUCM6.0 Server Add another Gateway RouterB, RouterA & RouterB interconnected through any networks and Using H.323 Voip Dial-peer.
I have a question here:
Is this a Valid configuration? If it is, for the perspective a routerA, It have two call legs both Voip dial-peer, is it valid? I have tested this scenario, it doesn't work on my network, Is something wrong with me, or I need some special config command.
Thanks for any advices;
Robert Li
1 ACCEPTED SOLUTION
Re: H.323 Gateway Issue?
if you attempt to join two voip dial peers you need a CUBE
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
Is it possible with CCME and Video Advantage?
no, CUBE is separate from CCME and VTA
java
java
Are you trying to send a call from your CUCM which is connect to a H.323 gateway on to another Voice Gateway? IF this is what you are trying to then yes this is possible using VOIP dial-peers. Post your config and I'll see if I can help.
Basically though I have a senario where my calls to my gateway and then I have a dial-peer which sends the call to another gateway that is accessible by my gateway and then that call is forward to the remote gateway phone or out the PSTN.
199
