Community Member
H320 legacy ISDN point-to-point devices over IP networks
What are the options to use my H320 legacy ISDN point-to-point devices
over an IP Network WAN link.
I just want this. What the options that I have ?
Tanks
1 ACCEPTED SOLUTION
Community Member
Re: H320 legacy ISDN point-to-point devices over IP networks
If you didn't get an answer you can try Cisco's terminal adpater.
F. Brown
Community Member
Did you by chance figure this one out yet?
Community Member
F. Brown
Community Member
Note that Cisco has end-of life'd the IPVC 3530 VTA.
Community Member
Most newer VC systems support both H.323 and H.320 interfaces. If you have an older system that support only H.320, it is recommended to get a new codec that supports both protocols if possible. The cost/complexity of adapters/gateways ( ~$4k) for this function is about as much as a new codec in many cases
229
