H323 Gateway Issue Furthermore
This issue is half solved under you suggestion. But I still have issue:
Scenario Below: A 3rdparty SIP phone(Xlite) controlled by a CUCM Server, Add a H.323 gateway(named HQ1) to this server, A software phone(CIPC) Controlled by a CUCME(named PSTN), CUCME interconnected with HQ1 use H323 protocol. Qeustions Below:
(1) shall we config CUBE on both Gateways?
(2) I can ring CIPC from SIP phone, but I can't pick up CIPC phone; and everything thing is ok regard with the opposite direction.
(3) Can you point out how media stream session established between the two phone? Need we a MTP?
Sincerely
Robert Li
1 REPLY
Re: H323 Gateway Issue Furthermore
Through test lab, I found some results.
(1) We only need config CUBE on HQ1 Gateway;
(2)The really question is that if a H323 call from outside to a CME, we can't pikup the call from a CIPC(sccp) phone controlled by CME, is there some solution?
(3) We don't need a MTP, and how media stream session establishment determind by media mode flow-through or flow-around
122
