header manipulation problem
I have a SIP trunk provider that requires me
1) to always use my account name in the "From" header, so I have to use header header rewriting to achieve this
2) to set the "P-Preferred-Identity" header to change the caller id (as From cannot be used due to point 1)
Now the header rewriting for 1) works fine, but 2) is bit more complicated, as I need to fetch the source number (ideally before it has been modified) and then use it in a new header line. (aka "copy contents from one header to another header in an outgoing SIP message")
From the "Conditional Header Manipulation of SIP Headers" document I would have assumed that the following works:
voice class sip-profiles 101
request INVITE peer-header sip From copy ".*<sip:(.*)@" u01
request INVITE sip-header P-Preferred-Identity add "P-Preferred-Identity: <sip:555123\u01@sipconnect.sipgate.de>"
But unfortunately it doesn't, "\u01" is being sent literally instead of the content:
Any ideas? I'm running CUBE on a 2901ISR with IOS version 15.3(2)T
Edit: Not sure what the difference between sip-header and peer-header is in this context, but using
request INVITE sip-header From copy ".*<sip:(.*)@" u01 (instead of the peer-header line)
doesn't work either.
If the profile you configured is passing the "vairable" instead of  the actual content, there is something wrong, please look at the following docs for a better understanding of how the feature works:
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb-gw-sipsip.html
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/cube_sip/configuration/12-4t/voi-condl-header.pdf
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/cube_sip/configuration/15-2mt/voi-condl-header.html
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
I've opened a TAC case and the problem was simple.
Modifying an existing heade works a single SIP leg in general but copying headers, working with variables requires multiple SIP legs, one to fill the variable and another to add/modify the header with its content.
As I only had a single SIP leg this cannot work.
Nevertheless, I've managed (again with TAC help) to get the desried functionality by adding
voice
   sip
      asserted-id ppi
and just modifying the header as needed.
665
