How to disable some codec type in 3660 VoIP gateway for incoming calls,
I am terminating voip traffic and using 3662 and would like to limit acceptable codecs to G723 while the originators select their prefered one G729,
so Please let me know :
How to limit acceptable codec types for incoming calls ?
Kassa
1 ACCEPTED SOLUTION
Re: How to disable some codec type in 3660 VoIP gateway for inco
voice class codec 1
codec preference 1 g723ar63
codec preference 2 g723ar53
codec preference 3 g723r63
codec preference 4 g723r53
codec preference 5 g729br8
codec preference 6 g729r8
codec preference 7 g726r16
codec preference 8 g728
codec preference 9 g726r24
codec preference 10 g726r32
dial-peer voice 1001 voip
incoming called-number .
voice-class codec 1
dtmf-relay h245-signal
When call comes to your router it will be matched with the following codecs, if you just want to use G723 remove others from the list.
Silver
The information which you are looking for could be found in the following documents.
Understanding Codecs: Complexity, Hardware Support, MOS, and Negotiation
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_tech_note09186a00800b6710.shtml
White Paper: Audio Codecs and Cisco Unity
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_technical_reference09186a00800875b7.html
Hope this helps.
voice class codec 1
voice-class codec 1
301
