Community Member
how to select the PRI for IP Phone users and FXO lines for fax lines
hi,
I have a CUCM and have ip phones and ata (fax machines) registered to it. I want that call initiated from phone users will chose the PRI for outside calls, While the Fax machines calls/faxes go through the FXO lines (both lines (PRI and FXO) are terminted on the same gateway).. the gateway is communicating with the cucm via h323. Now the configuration for this need to be done on gateway.. Kindly suggest how it will be configured..
Nareh
Hall of Fame Super Gold
Re: how to select the PRI for IP Phone users and FXO lines for f
Which protocol are you running on ATA ?
Community Member
SCCP
Silver
Since you are running H323, you can do it via cor list on gateway. Here is a sample configuration.
Lets say your Phone ranges 4xxx, and ATA number is 4205
dial-peer cor custom
name ata
name phone
dial-peer cor list ata
  member ata
dial-peer cor list phone
member phone
dial-peer voice 1 voip
answer-address 4...
corlist incoming phone
codec g711ulaw
dtmf-relay h245-alpha
dial-peer voice 2 pots
destination-pattern 9T
port 1/0:23
corlist outgoing phone
dial-peer voice 3 voip
answer-address 4205
corlist  incoming ata
codec g711ulaw
dial-peer  voice 4 pots
port 0/1/1
corlist  outgoing ata
you may need to change the answer address if you are sending 10 digit calling nubmer or not. Also, destination-pattern whether you are sending 9 or not
But the idea behind is, based on calling number, it will match incoming number and restrict the outgoing dial-peer
Hope this helps. commands may be slightly different then what actually is, cause I'm writing from memory, no router in front me now
-abu
294
