Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
How to two DID different bloks work in callmgr and voice gateway
I have trouble to install two different did blocks old did block(6828 7100 to 6828 7699 have been working for two years. Add new did block 6829 3000 to 6829 3199 recently. The PTT gateway 3745 router one ip address in Call mgr gateway has two isdn pri lines. PTT indicated now ISDN pri line 1 is for old did block and pri line 2 is for new did block. However, the gateway router selects the two lines i.e. s1/0:15 & s2/0:25 randomly. Thus, the caller shows the prime number if the call throws to the wrong line. How to fix the call throws to the right ISDN pri line.
Comments from PTT
Can the CallManager throw the calls to the respective lines? For example
for 6828 7100 -7699 it should throw to tp1.01 jgp1348 uam1-01 (ET 1081)
and for 6829 3000 3199 to tp1.02 jgp1348 uam1-01. I am sure this can be
done right? Otherwise the other range (6823 7000 - 7099) would not work
also. If you can ask your vendor on this
1 REPLY
Re: How to two DID different bloks work in callmgr and voice gat
Pls ignore my problem, i will post in IP telephony.
130
