incoming video call - help please
Hi Guru,
who can provide help for the below setup
diagram
PSTN----->T1 PRI--------Voice gateway-------CallManager---------Gatekeeper---------Video device
both call manager and video device registered with gatekeeper, video device has number as 2222, video device working internally between video devices and video advantage
in same time, video device is working for making outbound video call over T1 PRI by using a 2951 voice gateway
i am following cisco doc as
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a00807ca099.shtml
however, incoming video call is not working
on PSTN, telco sending last 4digits for the DID, and I have 8*DIDs for the video device, the 8*DIDs number are
1001 to 1008   (full DID is XXX-XXX-1001 to 1008)
from PSTN, when I call XXX-XXX-1001, there is only one B channel (h320 call) up, the rest chnannel can not be bouded together. any help appreciated
my 2951 config like
voice service voip
fax protocol cisco
h323
  emptycapability
  call start slow
voice class codec 10
codec preference 1 g711ulaw
video codec h263
video codec h263+
video codec h264
voice class h323 1
  call start slow
  h245 caps mode unrestricted
voice class called number pool 2001
index 1 2001 - 2009
voice translation-rule 1001
rule 1 /^1001/ /2222/
voice translation-profile 4Video
translate called 1001
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-dms100
isdn bchan-number-order ascending
isdn integrate calltype all
voice-port 0/0/0:23
voice-class called-number-pool 2001
translation-profile incoming 4Video
dial-peer voice 2222 voip
destination-pattern 22..$
rtp payload-type cisco-codec-video-h263+ 110
voice-class codec 10
voice-class h323 1
session target ipv4:10.1.1.1 (call manager IP, then call manager forward the call to gatekeeper)
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 1001 pots
description incoming video call to Large room
information-type video
incoming called-number 22..
bandwidth maximum 384
direct-inward-dial
port 0/0/0:23
558
