International Dialing 12 digits does not work
International dialing of 12 digits or more do not go through. 10 and 11 digits work fine. Callmanager 4.1(3), H323 2811 gateway IOS 12.3-14T7, using 7.011! dial pattern
Blue
Re: International Dialing 12 digits does not work
Assuming this is a PRI you will want to look at the ISDN Plan and Type that is being sent with the calls. A debug ISDN Q931 will provide this info. This will also confirm you are sending the correct digits.
Many carriers want to see Unknown or National if you are also sending 011. Call Manager will set this to International if you match on the @ macro. You can test this by setting up an explicit route pattern for a test.
Please rate helpful posts.
When you say the @macro do you mean in the dial pattern 7.011@, I am using 7.011!. That is the problem, the carrier is seeing international, the need to see unknown, which they are on 10 and 11 digit dialing but on 12 digit they see international. How do I change that?
What you need to do is to translate the 12 digit number to an unknown number plan. This needs to be done on the IOS router acting as the H.323 gateway
Refer to this documentation:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Hope this helps.
133
