Community Member
Interzone IOS GKs problem
I have the simplest 2 zones setup:
EP1 --- GK_A(MCM1) -- GK_B(MCM2) -- EP2
My configuration is:
MCM1:
gatekeeper
zone local MCM1 radvision.com 172.27.20.1
zone remote MCM2 test.com 172.27.20.2 1719
zone prefix MCM2 3013*
zone prefix MCM1 3024*
gw-type-prefix 1#* default-technology
no shutdown
MCM2:
gatekeeper
zone local MCM2 test.com 172.27.20.2
zone remote MCM1 radvision.com 172.27.20.1 1719
no shutdown
I am getting the following message while dialing from EP1 to EP2
debug gate main 10
*Mar 1 04:52:22.998: GK: QUEUE_EVENT (minor 0) wakeup
*Mar 1 04:52:22.998: gk_rassrv_lrq(30244): Tech-prefix match failed.
*Mar 1 04:52:22.998: gk_rassrv_lrq(30244): Matched zone-prefix 3024
*Mar 1 04:52:23.002: No proxy found, failing LRQ.
Can't find anything on "No proxy found message"
Can anyone help?
Silver
Re: Interzone IOS GKs problem
Try adding:
no use-proxy MCM1 default inbound-to terminal
no use-proxy MCM1 default outbound-from terminal
no use-proxy MCM2 default inbound-to terminal
no use-proxy MCM2 default outbound-from terminal
Please rate helpful posts!
Community Member
The change has solved the issue, thanks a lot
195
