IP/TV migrating from Catalyst 5500 to 6500 switch
We have moved from a Catalyst 5509 switch to a 6513 Switch and IP/TV is not working. Is there a configuration command I need to enter to get this to work?
Re: IP/TV migrating from Catalyst 5500 to 6500 switch
Are you running native IOS or hybrid (CatOS/IOS)
Also, are you routing on your 6513? (MSFC)
Anyway, you need to enable CGMP on the switch.
If you do route on the Cat, you also need to enable multicast-routing globally, and a multicast-routing protocol (e.g. PIM) on the relevant VLAN-interfaces.
This is what I have on my 6509 Sup1/MSFC/PFC running native IOS:
----- snip -----
ip multicast-routing
interface Vlan501
ip address 10.5.1.2 255.255.255.0
ip access-group 100 in
ip helper-address 10.9.98.4
ip helper-address 10.9.98.5
no ip redirects
no ip unreachables
ip pim dense-mode
ip cgmp
standby 1 ip 10.5.1.1
standby 1 priority 110
standby 1 preempt
----- snip -----
Hope this helps!
/Mikkle
Just running native with no routing. I know CGMP was enabled on the 5505 but I didnt see the enable for CGMP in the 6500 series command set. They had GMRP whic I enabled but had no effect. I'll give it a try and see if that works.
289
