09-27-2005 01:01 PM - edited 03-17-2019 08:31 PM
I'm using Netmeeting to test inter-zone calls through an IPIPGW. The IPIPGW registered in the zone0-gk zone should be used to establish the calls between zones.
I have two local zones, zone1 and zone2 and I'm using NetMeeting to test basic connectivity, with one endpoint (1000) registered in zone1 and another (2000) in zone2.
When a call is placed from 1000 to 2000 a call arrives at 2000 from the ipipgw. When this is accepted, another call arrived from the endpoint itself. (The same occurs in the opposite direction).
I'm not sure whether this is a configuration error with the IPIPGW/GK or a feature of NetMeeting.
voice service voip
h323
interface Loopback0
description IPIPGW/GK Source Interface
ip address 10.0.0.10 255.255.255.255
h323-gateway voip interface
h323-gateway voip id zone0-gk ipaddr 10.0.0.10 1719
h323-gateway voip h323-id ipipgw
h323-gateway voip bind srcaddr 10.0.0.10
interface FastEthernet0/0
ip address 192.168.0.100 255.255.255.0
ip route-cache same-interface
duplex auto
speed auto
dial-peer voice 1 voip
destination-pattern 2...
session target ras
codec transparent
dial-peer voice 2 voip
destination-pattern 1...
session target ras
codec transparent
gateway
timer receive-rtp 1200
gatekeeper
zone local zone0-gk test.com 10.0.0.10 invia zone0-gk outvia zone0-gk
zone local zone1 test.com invia zone0-gk outvia zone0-gk
zone local zone2 test.com invia zone0-gk outvia zone0-gk
no zone subnet zone1 default enable
zone subnet zone1 192.168.0.14/32 enable
no zone subnet zone2 default enable
zone subnet zone2 192.168.0.18/32 enable
zone prefix zone1 1...
zone prefix zone2 2...
no use-proxy zone1 default inbound-to terminal
no use-proxy zone1 default outbound-from terminal
no use-proxy zone2 default inbound-to terminal
no use-proxy zone2 default outbound-from terminal
no shutdown
09-29-2005 04:31 PM
I'm still learning IP2IP GW/Proxy, so I may be totally off the mark, but wouldn't you want to use proxy for terminal to terminal connections? Netmeeting, after all, is a h.320 terminal if I'm not mistaken.
You have that functionality disabled via:
Seems like netmeeting is treating the ARQ from this GK and the H.225 from your netmeeting like two different calls.
Does enabling the use-proxy in/out from all zones and terminals help?
Something like:
use-proxy zone1 default inbound-to gateway
use-proxy zone1 default outbound-from gateway
use-proxy zone2 default inbound-to gateway
use-proxy zone2 default outbound-from gateway
10-01-2005 04:27 AM
I am thinking that this extra connection I'm observing may be the separate T.120 channel, which flows around the IPIPGW (from the documentation I've read). There does appear to be little information regarding the IPIPGW (including via-zones and via-zone Gatekeepers) which describes its operation succinctly.
10-01-2005 09:58 AM
Very little documentation, indeed!
I'm aware of an old Netmeeting T.120 issue but it doesn't sound quite the same. One was able to set up the initial video call, but when you started sharing data, netmeeting initiated an additional T.120 call which failed. Is this what you are referring to?
So, are you are able to set up the initial video or voice call? My understanding was that there was no successful setup.
Anyway, it might well be worthwhile to place a sniffer in front off or co-resident with the netmeeting receiving, or trying to receive, the call(s).
10-01-2005 10:01 AM
I just went back and re-read your original post. (Couldn't do that while writing before!)
Is the second connect immediate? I'm wondering what could be triggering the second T1.20 call?
10-04-2005 12:55 PM
It does appear that it's the T.120 session (tcp/1503) which is causing this second connection. Perhaps it's because the IPIPGW is implementing flow-around for T.120, and the IP addresses are different (this fits in with the "nbtstat -a" connections which show that the tcp/1503 connections are directly between the endpoints and not via the IPIPGW.
However, this aside, I am trying to get IPIPGW to 'proxy' a connection between two local zones. I believe this is achievable not least because it is possible to use the IPIPGW for intra-zone calls, so inter-zone (for two local zones) should also be possible.
The connection is made and I see the inbound and outbound dial-peers matched (all have 'codec transparent' configured) and the call is set-up but I don't see any video, only audio.
However, "show call active video" (attached) shows that there are two active H.323 call legs.
10-12-2005 01:57 AM
I have since tried this using OpenPhone instead of NetMeeting (just in case this was a NetMeeting issue, but I am still unable to use the IPIPGW to get up a video call between two local zones.
One OpenPhone believes it is transmitting video data, and the other believes it is receiving video data, but the receiving OpenPhone doesn't display the video (which is consistent with the behaviour observed with NetMeeting). The audio is working.
The output of "show call active video" shows the inbound and outbound audio legs, but only the outbound video leg, not the inbound leg:
Outgoing Channel Number = 259
Type = VIDEO
TX Bandwidth = 8250
RemotePort = 49590
LocalPort = 17538
SelectedQos = best-effort
Incoming Channel Number = 258
Type = AUDIO
RX Bandwidth = 63
RemotePort = 49592
LocalPort = 16766
Outgoing Channel Number = 258
Type = AUDIO
TX Bandwidth = 640
RemotePort = 49592
LocalPort = 16766
Examples on CCO show configurations for using the IPIPGW between an endpoint in a local zone and a remote zone endpoint. I'm unable to find any examples of the use of IPIPGW to set up a call between endpoints in local zones.
