IPMA -Both phones in a pair ring simultaneously
I have a question about IPMA configured for proxy mode on CCM 4.1(3).
Is it possible to have the assistant/manager pair of phones ring simultaneously for an incoming call?
Thanx,
NB
Hall of Fame Super Red
Re: IPMA -Both phones in a pair ring simultaneously
Hi Nadia,
I thought that this was a pretty interesting question. Unfortunately, after much searching I can't find a way to accomplish what you are looking for. I am guessing that you want Sahred-Line funtionality (where both phones do ring simultaineously) with a Proxy-Line setup. I can't see this being possible :(
Hope this helps! I know that it probably doesn't.
Rob
Hi Rob,
I too was unable to find any information on this request.
Is it possible to setup a shared-line configuration for this pair while keeping the config for other pairs using Proxy mode?
Thank you,
NB
Hi Nadia,
It is possible to run both Shared-Line Mode and Proxy-Line mode in the same CCM cluster. Have a look;
The Cisco IP Manager Assistant (Cisco IPMA) feature enables managers and their assistants to work together more effectively. Cisco IPMA supports two modes of operation: proxy line support and shared line support. The Cisco IPMA service supports both proxy line and shared line support simultaneously in a cluster.
Note: Cisco IPMA with proxy line support coexists in the same Cisco CallManager cluster with Cisco IPMA with shared line support.
From this excellent doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803f3ab3.html#wp1071923
Hope this helps!
Rob
Hi Rob,
Thank you for the information and the link provided.
NB
153
