IPVC 3511 Setup Wizard problem
I am running sw v4.1.9 with EMP sw v3.1.2 on IPVC-3511.
The setup wizard is popping up every time when I click on the MCU icon. H323 GW is configured and SIP is disabled. Is there a way to disable the setup wizard from popping up?
1 REPLY
Re: IPVC 3511 Setup Wizard problem
Figure this out. Just need to put all the info (including SIP domain name, even if you are not running it) into via "Setup Wizard" and it will goes away.
133
