IPVC PRI Module All B-Channels used for single call
I am using an IPVC 3545 with a PRI module. When calling into the PRI Mod, I can check status and all 23 B channels are in use for a single call.
If I place a call to the outside through the PRI Mod, the correct channels are used.
Pleas advise.
1 REPLY
Silver
Re: IPVC PRI Module All B-Channels used for single call
Check for Configuring ISDN Channel Bonding Settings for Downspeeding .
The default setting for PRI gateways is 30, means all channels will be used if its selected.
You can adjust the number of channels required.
http://www.cisco.com/en/US/products/hw/video/ps1870/products_administration_guide_chapter09186a00804cc05b.html#wp1041941
121
