Issues with SIPnbound dial peer
Dear All,
I am trying to configure my first CME with SIP.
Outbound Calls are working ok, however I am getting fast busy for inbound.
I believe my dial peer is okay and I want for testing to translate the number called to the extension 17.
Debug gives me this
*Aug 30 12:32:57.146: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=03303801031, Called Number=03303801031, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=03303801031
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
*Aug 30 12:32:57.146: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=03303801031, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
*Aug 30 12:32:57.146: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
My dial peer config is
voice translation-rule 1
 rule 1 /03303801031/ /17/
voice translation-rule 350
 rule 1 /^999$/ /999/
 rule 5 /^9\(.+\)/ /\1/
voice translation-profile INCOMING
 translate called 1
voice translation-profile strip9
 translate called 350
dial-peer voice 1 voip
 description Outbound 11 digit numbers starting with zerob
 translation-profile outgoing strip9
 destination-pattern ^90[1-9].........
 session protocol sipv2
 session target sip-server
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 2 voip
 description Outbound other numbers
 destination-pattern ^9...T
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 999 voip
 description incoming calls
 translation-profile incoming INCOMING
 incoming called-number 03303801031
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
1 REPLY
Review this document about
Review this document about dial peers and it should answer any questions you have.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html
31
