Issues with voice class sip-profiles
Hi all, Sorry if this is the wrong place for this.
I'm having an issue with my SIP provider, They seem to add a Diversion on any incoming calls. This makes the incoming call look very annoying on the screen.
"Forward <calling number>
<calling number>
For <called number>
By <called number>"
Received:
INVITE sip:xxxxxxxx@58.174.xxx.xxx:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 125.213.160.81:5060;branch=z9hG4bK17dd5a0514c97f9b6-b0645-0
Max-Forwards: 70
Contact: <sip:087127xxxx@125.213.160.81:5060>
To: <sip:xxxxxxx@58.174.xxx.xxx:5060>
From: "087127xxxx"<sip:087127xxxx@125.213.160.81:5060>;tag=38527855-co7225-INS001
Call-ID: 14ef-42d-821201001758-img-05-mas-0-125.213.168.6
CSeq: 722501 INVITE
Content-Type: application/sdp
Supported: 100rel
User-Agent: ENSR2.5.4
Content-Length: 451
Diversion: <sip:6187200xxxx@125.213.160.81>;reason=unconditional
I have been trying to use a voice class profile to remove this but placing this on my incoming dial peers and my sip does not remove this diversion line.
This is on a UC520 running 150-1.XA3a
voice service voip
sip
  registrar server expires max 3600 min 3600
  localhost dns:icey.mine.nu
  no update-callerid
  sip-profiles 1
voice class sip-profiles 1
request INVITE sip-header Diversion remove
request ANY sip-header Diversion remove
Debug of voice dialpeer inout:
014012: Sep 21 00:17:22.344: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2633
Dial Peers:
dial-peer voice 2633 voip
corlist outgoing call-domestic
description ** Australian Domestic Pattern via SIP **
translation-profile outgoing SIP_Outgoing
destination-pattern 0[2-9].......
session protocol sipv2
session target sip-server
voice-class codec 1
voice-class sip profiles 1
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 2901 voip
description ** Inbound Dial Peer - SIP **
translation-profile incoming SIP_Incoming
incoming called-number .%
voice-class codec 1
dtmf-relay rtp-nte
no vad
Any one have any ideas?
Ben
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: Issues with voice class sip-profiles
The SIP profiles feature applies for outgoing SIP messages. In your scenario, the inbound SIP INVITE is not routed to another SIP endpoint across a voip dial-peer (i.e. it is not a SIP->SIP CUBE  or TDM->SIP call flow) and hence the SIP profile is not taking effect.
We can use translation profile to remove the redirect number :
voice translation-rule 1
  rule 1 /61872001234/ //
voice translation-profile strip-redirect
   translate redirect-called 1
  translation-profile incoming strip-redirect
Arun
Configuration looks fine. Can you please collect "debug cssip all" along "debug voip ccapi inout" during low call volume?
Arun
Please see attached file.
Kind Regards,
Ben
Arun
3573
