Community Member
Load balance multicast stream
Hi, i have the same stream coming from 2 different
directions. The 2 routers in the multicast server are using hsrp. My question is, can i load balance the stream?The method in use is SSM.
1 ACCEPTED SOLUTION
Silver
Re: Load balance multicast stream
PIM (dense/sparse) will not load balance multicast packets due to prune behavior to prevent duplicate packets. However, GRE tunnel(s) can be used to "load balance" multicast traffic. There is also another global command "ip multicast multipath" which allows load balancing But it will only load balance If multiple sources exist for the same group(s):
Silver
Community Member
How did this work out? Did this work for you?
I am hitting the same issue and looking for a simple way to load balance SSM MC with a L3 switch if at all possible.
I am going to lab this up and give it a shot.
Thank you,
-Steve
580
