Low latency Queue(LLQ) maximum bandwidth allocated - QoS
All,
What maximum bandwidth can allocated in LLQ queue for traffic real time ? For exemple when use bandwidth 512kbps, and allocate for real time (EF) 384kbps to some apllication.
1 REPLY
Re: Low latency Queue(LLQ) maximum bandwidth allocated - QoS
It is up to you: you can allocate as much as you can. But world practice shows that by allocating more that 35-50% to real-time traffic (LLQ [Voice + Video]) might cause you some problems. (“Cisco AVVID Network Infrastructure Enterprise Quality of Service Design” Solutions Reference Network Design)
Also remember the 75% rule: by default CISCO will let you allocate only 75% of available bandwidth. Using max-bandwidth command you can change the % portion to 100% if you need.
Configuring LLQ usually you need to thing about minimum of 3 aspects:
1. How much to be allocate for Priority queue
0 - 35%
2.How much to be allocated for other defined classes
Do not forget about default class: all unclassified traffic will fall under “default” class
35 - 75% (75% by default, optional 100%)
Vakhtang
288
