Lucent G3 PBX connect to VIC-2FXS issue
some problem in this case:
phone---Lucent G3 PBX--fxs----Router--------------Router----fxs---phone
left side can call right side, but right side can't call left ,the phone not ring.
My router is cisco2611XM with NM-2V and VIC-FXS, ios version is ip plus 12.(13)T
I have this configuration on my FXS port
voice-port 1/1/0
cptone HK
voice-port 1/1/1
cptone HK
But I need to kno how configure the trunk-group on my PBX ... which type of signal , what group type , trunk type etc.. etc
thanks.
1 REPLY
Silver
Re: Lucent G3 PBX connect to VIC-2FXS issue
I see from your topology that you are using a fxs port to connect to your PBX. This is not a supported configuration. The reason behind it is the fxs port cannot pass on the dialed digits out to the PBX. This is the reason you are able to dial in one direction and not from the other side.
You should either connect a FXO or an E&M port with a compatible port on the PBX.
156
