Max length of cat5 for PoE
hi everybody,
can you tell me the max length of cat5 for PoE when I connect from switch to ip camera?
Thanks and best regards,
Hall of Fame Super Gold
Re: Max length of cat5 for PoE
The same as for all ethernet of any speed, cable spec, PoE or not: 100 meters.
The max length of Ethernet is about 100m,
but also in my experience if use cat6, it give you distance about 150m
but look in general :
the max is 100m that is sure, between 100-160m it will work but you can not sure
There is another recommended solution
if your distance more then 100m, you can use Repeater in the medial the will regenerate the signal
I hope this will help you
If this helpful plz rate
thanks all. These information is very useful for me.
You are welcome, please remember to rate useful posts clicking on the stars below.
15583
