Community Member
mean of incoming called-number .
I'm just going through all my gateways and I noticed that I have a dial-peer with "incoming called-number ." (notice the singe dot at the end). What is the purpose of a single dot for the incoming called-number? Thanks in advance
1 REPLY
Hall of Fame Super Gold
Re: mean of incoming called-number .
Actually means, any number. Differently from "destiaion-pattern", "incoming called-number" does not support the concept of timeout. That is, you can put a T at end of string, but is not used.
244
