need to know about compatible switch or PBX system
hi,
we are settig up a VOIP network.my problem is ..
I have one E1 from pstn and the pstn switch is configured in such way that it support only to switch not the hdsl modem or dirct AS5300 but i have Hdsl modem connecting to my AS5300 gateway.so, please suggest ASAP which Switch or PBX System should i use to get my setup working.
waiting for reply with your kind suggestion.
thanks
1 REPLY
Silver
Re: need to know about compatible switch or PBX system
For Voice support you should go for E&M signalling and HDSL will not support voice.
Also in E&M signnalling itself there are different kinds.
Plesae refer the below URL for your setup for integrating PSTN PBX Switch with AS5300. Particlarly look in for the PSTN PBX switch with AS5300
http://www.cisco.com/warp/public/788/voip/voip_cas.html
130
