Netmeeting problems when calling via PSTN
When I call from Netmeeting to an end user via PSTN
the call is cleared (Normal cleared) after connection.
From a IP phone it works fine !!
See below 1) config extract and 2) debug isdn q931
Any tips and/or experience would be appreciated.
1) Config extract:
voice service voip
h323
h450 h450-2 timeout T4 10000
h450 h450-3 timeout T1 10000
h245 tunnel disable
h245 caps suppress nte
interface BRI2/0
description PSTN
no ip address
isdn switch-type basic-net3
isdn overlap-receiving T302 5000
isdn incoming-voice voice
isdn sending-complete
isdn outgoing display-ie
dial-peer voice 100 voip
destination-pattern 602
signaling forward none
voice-class h323 100
session target ipv4:172.16.12.51
dtmf-relay h245-alphanumeric
codec g711alaw
2) debug isdn q931 output
VoIP-GW-ARGO#sh deb
The following ISDN debugs are enabled on all DSLs:
debug isdn error is ON.
debug isdn q931 is ON.
VoIP-GW-ARGO#
Dec 19 16:02:03.432: %ISDN-6-LAYER2UP: Layer 2 for Interface BR2/0, TEI 69 chanp
Dec 19 16:02:03.436: ISDN BR2/0 Q931: TX -> SETUP pd = 8 callref = 0x40
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x83
Display i = 'Gilberto Rodoni'
Called Party Number i = 0x81, '0794223415'
Plan:ISDN, Type:Unknown
Sending Complete
Dec 19 16:02:03.673: ISDN BR2/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xC0
Channel ID i = 0x89
Notification Ind i = 0xE8
Dec 19 16:02:08.196: ISDN BR2/0 Q931: RX <- ALERTING pd = 8 callref = 0xC0
Progress Ind i = 0x8288 - In-band info or appropriate now available
Dec 19 16:02:10.676: ISDN BR2/0 Q931: RX <- CONNECT pd = 8 callref = 0xC0
Display i = 'FR. 0.10'
Date/Time i = 0x030C131102
Connected Number i = 0x00A3
Dec 19 16:02:10.680: ISDN BR2/0 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x40
Dec 19 16:02:10.712: ISDN BR2/0 Q931: RX <- FACILITY pd = 8 callref = 0xC0
Facility i = 0x91A11B0202EDC50201213012A10D810346522EA20681010A82010182
- ETSI Supplementary Service, Invoke, AOC-D Currency
Dec 19 16:02:10.776: %ISDN-6-CONNECT: Interface BRI2/0:1 is now connected to un
Dec 19 16:02:10.776: ISDN BR2/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x40
Cause i = 0x8090 - Normal call clearing
Dec 19 16:02:10.917: ISDN BR2/0 Q931: RX <- RELEASE pd = 8 callref = 0xC0
Facility i = 0x91A11A0202EDC60201233011300FA10D810346522EA20681010A8201
- ETSI Supplementary Service, Invoke, AOC-E Currency
Dec 19 16:02:10.925: ISDN BR2/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x40
Silver
Re: Netmeeting problems when calling via PSTN
Take a look at this document on Outbound ISDN Calls Fail when Originated from NetMeeting or Similar Third Party H.323 Devices. Should be of help.
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_tech_note09186a0080093f62.shtml
use
Bearer capability speech
on the voice-port of the outgoing ISDN-Line.
Under some circumstances the router doesn´t know that the netmeeting-call is voice and so it cannot connect to a voice-device outside.
I cannot better disclaim, try if it works.
Horst
142
